Re: Need gasket for oil filter base for a F-12 or
Posted by El Toro on December 26, 2006 at 15:29:05 from (152.163.100.65):
In Reply to: Need gasket for oil filter base for a F-12 or F-14 posted by tractor hank on December 26, 2006 at 15:06:12:
If you have access to that area on the engine block where that oil filter base is bolted. You can use a piece of gasket material and use a small
peen hammer and make your gasket by tapping on the gasket material. You need to keep the gasket material from moving. We made them in at work all the time. I still do it since I retired. Hal
