Re: H block
Posted by Janicholson on December 27, 2006 at 17:53:21 from (66.188.149.191):
In Reply to: H block posted by Thumbanger on December 27, 2006 at 16:18:44:
If it is not a Core plug (often called incorrectly a freeze plug) it is the block drain as noted below. JimN
