Re: Temp gauge colors
Posted by Roger Mills on December 28, 2006 at 09:26:21 from (71.213.68.25):
In Reply to: Re: Temp gauge colors posted by Janicholson on December 28, 2006 at 08:38:48:
Ja, Ordinarily I would agree, IF, the temp gauge was at the water outlet of the engine as it is in later pressure systems with a water pump etc. it would be correct. I just received a call back from OEM and, per Thurman(sp), the gauges they sell are new from Rochester-but-the scale is NOT calibrated the same. Correct calibration for the Thermosiphon, non pressurized, inlet side gauge IS 20 degrees cooler at the color band markings. He is going to check with Rochester to see if he can get them to re-calibrate that part number gauge. More as I get it.
