Re: Farmall A head gasket with or without water pu
Posted by TractormanNC on December 29, 2006 at 17:22:20 from (209.42.180.99):
In Reply to: Farmall A head gasket with or without water pump posted by Greg-N-CA on December 29, 2006 at 16:42:39:
Man it's been 30 yrs since I've worked on a SA. The early SA's used a siphon system to circulate water and needed the large holes in the gasket. The later ones with a water pump used a gasket with smaller holes. Either someone has put the wrong gasket on your tractor or has added a water pump to an older tractor. Sorry I don't know the serial # when this was done. The gasket with small holes will work fine.
