Re: Re: Re: Check oil levels
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Ludwig on February 03, 2000 at 16:38:11 from (216.41.30.125):
In Reply to: Re: Re: Check oil levels posted by John on February 03, 2000 at 16:31:01:
On our '52 Super M the axles will squeek a bit if there isn't enough grease in there.
Uncle Reg was absolutely convinced I should only put one pump in there per year, but that didn't jive with my grease experience so I pump and pump, probably put 1/4 tube in every year, considering that the tractor mows exactly 1 field once each summer I figure that isn't too bad.
Post A Followup
: Re: Re: Re: Re: Check oil levels
