Re: Re: Check oil levels
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by John on February 03, 2000 at 16:31:01 from (207.172.11.148):
In Reply to: Re: Check oil levels posted by The Red on February 03, 2000 at 14:28:00:
Thanks, Red. I think I'll change the oil this weekend if it doesn't snow again... About the axle grease -- so it's not that important if I don't pump until I see fresh grease coming out somewhere (like Dad always taught to do when greasing)? I've probably put at least three tubes of grease into each side and I wanted to check to make sure I wasn't doing something stupid. Dad didn't teach me how to load a grease gun very well... (4 tubes each side if you count the grease on ME! You'd think that a country of engineers who can build the Saturn 5, break the sound barrier and build a stealth bomber could design a grease gun that's easy to load)
Post A Followup
: Re: Re: Re: Check oil levels
