Re: Engine Swap
Posted by D Slater on December 30, 2006 at 08:46:58 from (64.12.116.65):
In Reply to: Engine Swap posted by Dave S. on December 30, 2006 at 05:31:14:
For a complete 300 into H the only things that are not bolt on and need modified to work are the crank vent pipe to air cleaner, air cleaner pipe or connection to carb. and choke rod. Some bolt on changes, fan blades are little bigger outside diameter on 300 than H. If your not using 300 live hydraulic pump you will need a distributor drive from a later H or SH. Your H flywheel and clutch will bolt up, but if you plan to pull it hard you may want to use a late H or SH 10.5 inch clutch set up. Fitting in block for oil pressure gauge needs changed and its a little more easy to do when you have frame rail removed. Governor throttle control lever and shaft needs switched or H governor put on 300 engine. If you do that put the throttle shaft and tube going to carb. from 300 onto H governor.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
