Engine Swap
Posted by Dave S. on December 30, 2006 at 05:31:14 from (24.225.15.109):
Will a 300 or 350 Farmall engine fit in a 45 H and what has to be changed to make it work (flywheel,clutch,pressure plate motor mounts etc)?
