Re: IH 1586 Problem
Posted by Janicholson on April 12, 2009 at 15:21:29 from (66.173.50.24):
In Reply to: IH 1586 Problem posted by AE on April 12, 2009 at 14:59:52:
If overflow of radiator, it is a sign of combustion gasses or engine oil, getting into the coolant.
From head gaskets, cracked head/s, pinholes in sleeves, and broken oil cooler tubes, A comprehensive testing procedure is needed.
Is there water in the oil?
Smell the coolant
What is the coolant contaminated with? Let it stand in a mayo jar to see if it separates.
Have a test (or use a test kit) to check the coolant for specific materials.
Pressure check the system pan on, and if dropping, pan off.
There will be other specific ideas coming along.
JimN
