Re: Farmall 27V Sicle Bar Mower
Posted by BGDean on January 01, 2007 at 09:48:51 from (72.11.15.199):
In Reply to: Re: Farmall 27V Sicle Bar Mower posted by TomH in PA on January 01, 2007 at 08:36:16:
TomH,
It"s fairly well together. The hydraulic cylinder is off and there is a long bar about 3/8" dia. bent 90deg on one end with a pulley block on it. I assume thats for the rod to slide on when raising and lowering. Not sure how that fits. Thinking about removing the drawbar attachment and adding some steel to pickup the top link of the three point. The V shaped frame looks about the right width to fit the lower arms. Going to use it on a compact New Holland. If I put a drawbar on the three point I"m concerned about the rotation of the drawbar, won"t be fixed like an old H or M has.
I think the 25V was pretty much the same but maybe with a manual lever to raise and lower. Would you be willing to part with it or make a copy?
