H belly hydraulics
Posted by H Field on January 01, 2007 at 13:05:51 from (70.241.242.10):
I have a 1947 H with the belly mounted hydraulic system. It started
leaking fluid bad when the remote cylinder is used. I took it out
and had the imput shaft seal replaced. The first time the remote
cylinder reached the end of the stroke the seal started leaking
again. Any ideas?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
