Re: H belly hydraulics
Posted by JayWalt on January 01, 2007 at 13:21:10 from (24.223.138.48):
In Reply to: H belly hydraulics posted by H Field on January 01, 2007 at 13:05:51:
Are you referring to the pump actually leaking or the remote cylinder? Is the shaft seal on the pump or the cylinder?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
