Re: I Give Up
Posted by teddy52food on January 02, 2007 at 06:22:22 from (204.73.107.177):
In Reply to: I Give Up posted by JayWalt on January 01, 2007 at 15:45:51:
The 3rd brush is not fixed. There is a slotted screw on the back side that holds it in position. Loosen this screw and move the brushes farther apart & it will charge less. I have grounded the field and set the brush to charge a steady 10 amps and had no trouble since. Make sure both belts are tight if it does not want to charge.
