Re: I Give Up
Posted by F-Dean on January 02, 2007 at 06:25:58 from (67.72.98.84):
In Reply to: I Give Up posted by JayWalt on January 01, 2007 at 15:45:51:
BIG JOHN has been putting a 12-volt Hitachi #14231 alternator on several tractors in place of a generator under the hood. This alternator was used on 1978-79 Nissan 620 pickup with a 2 liter engine and a 1980 Nissan 720 pickup with a 2 liter engine. At NAPA it is part #2138130. The cost of a rebuilt alternator is approximately $50 + core (And they won’t take a generator as a core). The alternator is 4 1/2" in diameter and 7" in length and will go right on the original mountings on the tractor. Use an 8" x 3/8" bolt and some pipe and/or washers for spacers. Being Hitachi means that it is METRIC. You will need to drill out the mountings to 3/8". The tension adjusting bolt is also metric thread. The alternator is a three (3) wire set up which can be converted to one (1) wire. There are spade connections labeled S & L and a BAT post connection. The L spade is for the idiot light and can be disregarded. Use a jumper wire from the S spade to the BAT post and you are good to go. The pulley maybe a split type that you can widen using a spacer (once again metric). You may need to use a disc type lock washer and some “Locktite” because there won't be room to reuse the split lock washer that comes with it. I put the washer between to parts of the pulley to make it fit the existing belt. I have installed 4 Hitachi alternators – two were split pulley and the most recent two were not. There is a built in regulator and a resister to keep the battery from feeding back to the alternator. This is a sweet fit under the hood that he has used on H's, M's and W models, also Cubs and many others. I add the following from my experience: Be sure to switch the polarity of the battery to Negative ground to avoid damaging the Alternator. Consequently, you need to switch the wires on the coil, if you are using a coil. Use a plastic covered connection when you connect the jumper wire from the S spade On a Farmall M, turning the bracket upside-down will allow the alternator to fit nicely inside the hood using the existing generator belt. I have installed two Hitachi #14231 alternators on two Ms and two on F-20s without any problems. I have placed a picture of this instalation under Parts & Pieces in the left-hand column
Home
| Forums
Today's Featured Article -
A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
