Re: timing? 230? plug gap? electronic ign.
Posted by Bob M on January 02, 2007 at 07:49:09 from (151.190.254.108):
In Reply to: timing? 230? plug gap? electronic ign. posted by t.r.y. on January 02, 2007 at 04:14:41:
As John T mentions below, set the plug gap per the ignition mfr's recommendation. Or if you don't have gapping info I'd recommend about 0.045 - 0.050. (Keep in mind that within the ignition's ability to fire the plug, larger gap = better)
As for optimum timing for lugging, etc. set it per the owner's manual. I'm not familiar with the 230 but it's probably 0 deg (TDC) at low idle. Then check that the spark advances per spec (probably about 35 deg BTDC) at high idle RPM.
Keep in mind IHC engineers arrived at their timing spec after extensive experimentation and analysis! Deviations from factory timing generally cause less power and increased fuel consumption.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
