Re: I Give Up
Posted by Janicholson on January 02, 2007 at 09:17:38 from (66.173.50.48):
In Reply to: I Give Up posted by JayWalt on January 01, 2007 at 15:45:51:
Go to a library and look up delco type A generators in either tractor, or auto books from the 50s. (common as fenceposts) you will note that the system is not overly complex as a diagram, it is just the reality of the actual parts that seem inscrutable. If it will not charge with the field grounded, it may not be getting the cutout relay to close. There is a pull in winding on the cutout relay that senses voltage from residual magnetism in the field and connects the armature with the battery. This process starts the generator. If the regulator is not grounded to the tractor frame/engine/generator, it will not pull in the cutout relay. To see if this is the case, disconnect the A terminal from the gen, then use a jumper wire from the battery neg terminal to then just touch the armature terminal for a half second. There should be a spark (pretty healthy, but not a direct short) this spark tells you that the armature is able to conduct current through the windings to internal ground. (probably good output components in the gen) Next disconnect the F terminal from the Gen and use a ohm meter to see if it conducts from the F terminal to the third brush. If it does, (no resistance <1ohm) the field circuit is probably OK. and the regulator (or its ground) is the problem. Note of importance Farmers were often functionally able to do these types of repairs as a part of operating and Keeping their stuff functional. There is no reason you cannot. It is one component of the hobby that many of us treasure. Please do not despare. JimN
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
