Re: H Lift-All not lifting
Posted by chad Koel on January 02, 2007 at 14:59:00 from (64.90.82.37):
In Reply to: H Lift-All not lifting posted by Chad Koel on January 02, 2007 at 13:00:05:
Allright guys, I pulled the cover off the pump area on the belly
and was greeted by a flood of oily, watery sludge! However, the
cover was not on tightly so moisture could have entered from
the outside. When I fired her up, everything seemed to be
spinning just fine. The lower shaft I assume runs to the PTO(?)
while the "T" shaped coupling above must be the pump.
Evrything was spinning fine but no oil getting pumped. (pulled
the hose to the loader and tried to get some oil to run)
Still confused? (nothing new!)
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
