Re: charging a battery
Posted by JayWalt on January 02, 2007 at 15:32:17 from (24.223.138.48):
In Reply to: Re: charging a battery posted by Janicholson on January 02, 2007 at 14:47:02:
If you do use a fast charge, be sure to check the battery water afterwards. Use DISTILLED water to fill it up just to where the tube start. You will notice the meniscus as soon as it forms when the water level reaches the tube. A meniscus is the curvature that water has on the edge of a tube due to it being slightly adhesive. mecury's meniscus is opposite, kinda cool.
