where to get a oil filter base gasket and trans to
Posted by MartinD on January 03, 2007 at 16:47:37 from (216.81.109.187):
i need an oil filter base gasket,where the base meets the block,also need a gasket for the transmission cover(that big plate the seat mounts to)
