Re: where to get a oil filter base gasket and tran
Posted by NDS on January 03, 2007 at 17:28:25 from (205.188.116.133):
In Reply to: where to get a oil filter base gasket and trans to posted by MartinD on January 03, 2007 at 16:47:37:
Case/IH still has the gaskets if your local dealer does not want to order them (if they are not in stock) call Bermuda Ken.
45447D Gasket oil filter base
48646D Rear frame cover gasket
