Re: Crank Bearings
Posted by PORKY B. on January 03, 2007 at 20:48:18 from (67.58.192.101):
In Reply to: Crank Bearings posted by Patrick in Illinois on January 03, 2007 at 20:26:06:
Never assume anything, not sure measure crank up with micrometer. Check specs. with a proper shop manual.
