Re: Crank Bearings
Posted by jhb on January 04, 2007 at 05:49:03 from (64.198.83.87):
In Reply to: Crank Bearings posted by Patrick in Illinois on January 03, 2007 at 20:26:06:
Get some plastigage and determine if the mains are with in the correct tolerance. Very cheap and very easy.
