Re: Brake Oil Seals
Posted by D Slater on January 04, 2007 at 06:01:39 from (152.163.100.65):
In Reply to: Re: Brake Oil Seals posted by David Goode on January 03, 2007 at 17:38:33:
If you have drum brakes ask for seals for a M tractor bcause the original SM used disc brakes. Also only early M used a key on bull pinion and brake shaft for the drum, most are splined. Don't try to remove housing the seal is in from tractor from the outside. Parts need removed on inside first or housing will break.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
