Re: 15/30 S/No. Location
Posted by Loren in Iowa on January 04, 2007 at 06:33:38 from (207.177.2.187):
In Reply to: 15/30 S/No. Location posted by Nigel Apperley on January 04, 2007 at 02:56:33:
Check the engine block, toward the front. There should be a flat spot, I believe, on the right hand side. This serial number might match the tractor's serial number, which probably isn't anywhere else on the tractor. Without the serial number plate, this is as close as you can get to determining the actual serial number, unless the engine has been replaced. You may find some casting dates on the engine, or the gear case, that will give you a clue to the age of the tractor. We used the engine number, and had a new plate made, for our 15-30.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
