Questions for 350 Diesel Owners
Posted by migraine on January 06, 2007 at 08:59:25 from (71.231.54.158):
I plead a bit of ignorance here as we never owned or had use of 350 Diesel with continental motor. What was used as a starter aid in cold weather. I know it does not have glow plugs so was it a manifold air warmer or??? Do they start ok if everything is working? How was the power on this 193 motor and can you tweek them up a bit with fuel and rpm? Have chance to get a complete motor with pump,lines, manifolds and filters and kinda looking for some feedback from current and past owners. This motor was in a utility and I want to install it in a row crop. I have all the manual frame sheets and it appears that there was frame supports that held up the front of the motor. Any ideas where to find a pair of those and was the water pump and fan assembly interchangeable with any other models? Sorry about the long post but sure could use some help here. Thanks Migraine
