Re: 300 row crop behlen power steering
Posted by D Slater on January 06, 2007 at 18:16:14 from (205.188.116.133):
In Reply to: 300 row crop behlen power steering posted by ohio river farmer on January 06, 2007 at 15:50:37:
For the way IH did it you need the control valve last one on inside from order of removing. Regulator,safety,priority valve and pipe and fittings to connect the two. Orfice plug,Return hose and fittings to connect oil return line to reservoir drain plug hole,pressure hose,brace to keep hydraulic motor body from turning and front steering shaft or shorten yours to work.Coupling for steering shaft. Bunch of orings. Unless you want original get a power steering pump with reservoir, it will fit on top left side of 300 engine and run off a longer belt and you can just run hose to the behlen unit.
