1256 steering problems
Posted by Erik in WI on January 06, 2007 at 18:42:28 from (65.162.45.94):
My 1256, that I have owned for a whole 24 hours, has a bit of a problem, no steering after start up. It has no steering, manual or power, until the throttle is advanced to about half. This only happens after start up. The longer the tractor sits, the worse it gets. I think something is loosing its prime, the question is it the steering valve or is it the MCV pump itself? Also the Tell-Lite blinks until the steering works again. The steering works fine after it starts working, so I don't think it is the filter, but I am changing it anyways.
I am thinking it is the pump itself, there must be a bad check valve in there, is my thinking correct?
Thanks
Erik
