Re: 1951 Farmall M w/ 9 speed Question
Posted by r4etired on January 06, 2007 at 19:46:03 from (64.12.116.65):
In Reply to: 1951 Farmall M w/ 9 speed Question posted by IHC-Farmall on January 06, 2007 at 14:08:57:
The three companies that I know of that made the 9 speed were,M and W, they had operating linkage on the right side, Heisler, there's was on the left side and Behlen ,they used cable linkage,It entered the transmission thru the top left bolt in the torque tube.They drilled a hole thru the bolt and put a small compression fitting around the cable. Inside they are pretty much the same, Travel speeds are about the same.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
