Re: M backfires won't start! HELP!
Posted by Nebraska Cowman on January 07, 2007 at 14:50:29 from (65.165.16.117):
In Reply to: Re: M backfires won't start! HELP! posted by granger on January 07, 2007 at 14:41:59:
Yup, I'd say you have problems. Either broken gera jumped a tooth or two or sheard keyway. Yeah, I susspect the rotor would still turn, friction on the shaft would do that. And I wondered the other day why the pump split? Like maybe you are loading the system with too much pressure? You gotta have a relief valve somewhere. Maybe your tractor is trying to tell you something. They do that. Most of my education has come from the "school of hard knox"
