Re: Super A adjustable front end repair
Posted by JFay on January 07, 2007 at 15:48:37 from (71.233.237.91):
In Reply to: Super A adjustable front end repair posted by Mark in Wa on January 07, 2007 at 11:51:23:
I had the same issue on my 140. I replaced the pins which had become worn and welded up the holes on both the inside and outside pieces of the axles and ground them out to size. works great now.
Good luck.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
