Re: M backfires won't start! HELP!
Posted by Nat 2 on January 07, 2007 at 17:14:06 from (69.204.107.149):
In Reply to: Re: M backfires won't start! HELP! posted by granger on January 07, 2007 at 14:03:30:
Pull the distributor cap. If the rotor isn't turning, then you've got to pull the hydraulic pump.
The gear I'm talking about is the gear that goes on the front of the hydraulic pump.
If you didn't tighten the nut adequately, it could work loose and then the shock from the hydraulic cylinder hitting its end of stroke would finish it off.
