Re: M backfires won't start! HELP!
Posted by Janicholson on January 07, 2007 at 18:50:50 from (66.173.50.22):
In Reply to: Re: M backfires won't start! HELP! posted by granger on January 07, 2007 at 14:16:49:
If gears messed up in the fromt engine cover, they can affect operation (usually do). I would put the engine at TDC on Number one cyl (front). Do this by pulling the sparkplugs from that cyl and while it is cranked (by hand preferably) place your thumb, or a cork in the cylinder when it is on compression, it will blow your thumb out. Then watch the timing marks as stated below, to get it at TDC. Then pull the cap and look at the rotor. It should point to the #1 plug terminal inside the cap. If it does not, or if it is way hard to get it to TDC by the compression with thumb idea above, I would suggest it has broken parts in the timing gears. Do not try to start it or run it or pull it to get it going until these things are checked for sure. (sevier dammage can be created where minor damage is located now. As stated below, it is mandatory to have a working relief valve on the system. Hoses will split, castings will break, and danger is likely. If your M is factory Hydraulic, it is equipped (may not be working) if it is put together by others it may be missing the bypass pressure relief. Good luck, JimN
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
