Re: a different angle
Posted by Janicholson on January 07, 2007 at 19:29:41 from (66.173.50.22):
In Reply to: a different angle posted by Randy as in Randy-IA on January 07, 2007 at 19:04:16:
I do not think it will cause problems. I would clean the cover surface to bare metal and put a very thin whisp of chassis grease on the trans/dif casting. This will allow the RTV to seal, but come off when needed. It also allows the RTV to be on the cover for cleaning. Use only a skim coat, gobs of it comming out in the trans can get into places it is not needed. I would also use it under the bolt heads on the cover to keep water out of the casting (as much as possible). JimN
