Re: M backfires won't start! HELP!
Posted by EL Toro on January 08, 2007 at 05:43:32 from (152.163.100.65):
In Reply to: M backfires won't start! HELP! posted by granger on January 07, 2007 at 13:04:28:
Bring No1 piston to TDC on the compression stroke
then remove the distributor cap and see where your rotor is pointing. Pull the valve cover and see if both valves are closed on that cylinder.
Hal
