Re: duals on a m ?
Posted by Hugh Mackay on January 08, 2007 at 08:23:54 from (209.226.106.174):
In Reply to: duals on a m ? posted by muller2 on January 07, 2007 at 16:39:30:
muller: I had no problem dualing my 560, 84" axles with standard cast Farmall wheels, inside dished in and outside dished out. I was using 14" double bead rims with 16.9x38 tires. With outside wheels at end of axle and taking advantage of double bead rims, I had 4" between tires.
Smaller tires will give you advantage, single bead rims will reduce that advantage. It is still possible on an M with 13.6x38 tires. To go with much larger tires you'd need the double bead rims, assuming 84" axles. Longer axles will let you do it just about anyway you wish.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
