Farmall Super C Axle Length
Posted by Joe Kimbriel on January 09, 2007 at 12:35:56 from (136.200.52.33):
What should the rear axle length be on a 1952 Super C? Was there an option for long axles or short axles? Is there a normal rear wheel width for this tractor? Someone cut the axels off with a torch most likely to get it through gates or out of the barn!!!!!!
Thanks,
Joe
