Re: farmall A rebuild
Posted by El Toro on January 09, 2007 at 16:22:29 from (205.188.116.133):
In Reply to: farmall A rebuild posted by lundy on January 09, 2007 at 15:51:35:
Are you sure the valves have enough clearance?
I would set them at .017" cold. Did you use the old sleeves and pistons? The sleeves and rings may be worn if you did. This could be one of your problems with low conpression. Hal
