Re: Farmall C Not Charging
Posted by Janicholson on January 11, 2007 at 18:00:19 from (66.173.50.136):
In Reply to: Farmall C Not Charging posted by Scotty1 on January 11, 2007 at 17:52:07:
Yes. In the Search for area above, look for John T diagnosis. It is better than repeating it all. Also important is a diagram a few pages back about charging systems that included a diagram of the regulator and generator that helps. Good luck It will get going no problem. Make sure you know what you have, and the year makes a difference. If you have a light switch with LHDB on the front (four clicks and no OFF position, It originally had a 3brush generator, and a cutout relay, not a voltage regulator. JimN
