Farmall C Not Charging
Posted by Scotty1 on January 11, 2007 at 17:52:07 from (65.110.175.156):
Hi, I am working on a Farmall C that I Can't get charging. It's the original 6 volt system with generator and voltage regulator. I've been keeping the battery charged with a battery charger, so I do have battery voltage of 6 volts . When I check voltage at voltage regulator I have battery voltage at all the terminals expect the one terminal by it self on the left side of the regulator when looking at it on the tractor. I replaced the voltage regulator but it didn't make any difference. With the tractor running I can touch the outside terminal on the genarator to ground and it makes a soft spark ? Is there a easy way to test the genarator ? Thanks for any help !
Scotty
