Re: implements for a Farmall H
Posted by gene bender on January 14, 2007 at 03:48:51 from (67.55.226.214):
In Reply to: implements for a Farmall H posted by RDF1 on January 13, 2007 at 23:16:47:
Have you checked the pressure the pump has? If it is in good shape it sure will raise anything you can hook up. Now if you think you need down pressure you will have to add a two-way valve in the system. That will be an easy fix. Too bad you found bad advise.
