Re: Hey Kfox
Posted by kfox on January 14, 2007 at 08:22:24 from (63.18.175.123):
In Reply to: Re: Hey Kfox posted by Pat-CT on January 14, 2007 at 07:10:55:
third party image
Yep, its a Saginaw. It really works well on the
belly pump on my H. If it ever quits raining here, I'll get some better photos. I kinda did a overkill on my plumbing. I hooked the lower ends of the cylinders into the drain on the pump: just in case I needed more oil capacity. It wasn't necessary. I have enough oil to raise the lift and suck oil into the other ends of the cylinders without adding oil. I guess it keeps air out of the other ends of the cylinders. ken
