Will a Flail Mower For a Farmall Lo-Boy fit Farma
Posted by BUSTEK on January 14, 2007 at 12:19:44 from (209.23.10.11):
This is a 48" Mott finish flail mower which was recently removed from a Cub Lo-Boy tractor. The bearings seem to be in good shape with no growling or unusual noises. The deck is solid with some minor rust holes evident. All brackets and pulleys are included. This is a heavy and awkard item so it is for local pickup only.
Ok, thats the description in the ad I looked at. Does anyone know if this will fir on the 1949 Cub I have? The Cub had a sickle bar mower already attached, but I"m thinking of removing it so I can mow ditches and "downhill" more easily.
I also have a 1950" Farmall A..anybody know if this will for that? The Farmall A has no sickle bar or pulleys, just the PTO shaft.
Thanx
Ken
