Re: Need help with MD fuel problems
Posted by Geoff NY on April 12, 2009 at 17:31:28 from (24.185.231.35):
In Reply to: Need help with MD fuel problems posted by BruceS. on April 12, 2009 at 17:07:24:
at the top of the water trap there is a bleeder. Also at the top of the two filters are bleeders. the one on the right is bled with motor off the one on the left is bled with motor running on gas and the throttle open a little. also when these have been purged, bleed each injector with motor running. The fuel return line leak is a plumbing problem that will need to be fixed. Get a book it will help you immensly.
