Re: Hour meter for Super C
Posted by JD Humm on January 15, 2007 at 10:37:34 from (70.128.255.146):
In Reply to: Re: Hour meter for Super C posted by Harold Hubbard on January 15, 2007 at 07:39:42:
What Harold said is true, they are not as manuverable. I modified the piece that connects to the steering pad on the tractor bolster on one end and connects to the tie rods on the other end by making a completely new piece that is one inch longer, this allows the front tires to turn a lot shorter than the standard piece allows. It does however, make steering just a little bit tougher because it requires a little more leverage to turn the front tires set up this way.
