Re: Super A clutch problem
Posted by Curt Cooke on January 15, 2007 at 13:03:27 from (12.150.39.226):
In Reply to: Super A clutch problem posted by Russell S. on January 15, 2007 at 11:09:10:
What's happening is that the fork assembly that moves the throw out bearing into the clutch levers is making contact with the spinning pressure plate. It's not a big deal if you don't have to push the pedal down that far to disengage the transmission. If you do, you should consider replacing the clutch because things are worn and not perfect anymore. When everything is right and adjusted proper, that won't happen
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
