Re: Farmall H Gear Oil
Posted by chuck46 on January 15, 2007 at 19:34:18 from (64.136.27.229):
In Reply to: Farmall H Gear Oil posted by Gary Puckett on January 15, 2007 at 17:53:49:
Hi, I am a big believer in Hy-tran for all tractors I use. My H and WD9 have had it for more than 30 years, I have magnets and filters on them so I can see how much wear there is, and after several thousand hours I know they are doing better than they did with the heavy oils. I used to see a bearing turn in the housing once in a while, but not now. I put a street ell in the check hole, turned up so the level is 2 inchs higher. Good luck, Chuck
