Re: IH 384 Injectors need bleeding repeatedly
Posted by Bernard le mécano on January 16, 2007 at 10:36:51 from (207.134.205.166):
In Reply to: IH 384 Injectors need bleeding repeatedly posted by Ken Pearson on January 15, 2007 at 16:54:28:
Hi Ken, it have a check valve on the return line, (a special banjo bolt on top of the filter base).Or a leak in the primer pump.
Bernard le mécano Québec Canada
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
