Re: attn chads 450 cam
Posted by ChadS on January 17, 2007 at 09:39:37 from (66.228.96.172):
In Reply to: attn chads 450 cam posted by olivereater on January 16, 2007 at 16:59:56:
Ive got new 450 cams ready to go. I can get you the crank, pistons and everything you need to put one together, its not an original M&W crank, its a stroked crank. Usually what we do is, if someone needs a kit built, send us the rods, and the crank and we build the rods, and have the crank built and shipped back to you. We can also do most of the grinding needed to clear 6 inch, and tell you where to grind in the block so the rods clear. Its not hard at all to do. 574-893-7437 ChadS
