Re: Distibutor for a Cub
Posted by Jim Becker on January 17, 2007 at 09:40:03 from (71.164.210.94):
In Reply to: Distibutor for a Cub posted by Tony Tye on January 16, 2007 at 18:48:18:
Even if the bushing is worn, redoing the bushing is probably still the cheap/easy way out. Buy a used one, you may still need to rebuild it. Fix what you've got and at least you will know what you have.
Distributors from other models are nearly the same as the one for the Cub. However, different engines have different spark advances. You really want the advance to be the same after you are done.
