Re: 12 Volt Coil
Posted by Janicholson on January 17, 2007 at 10:31:36 from (199.17.6.122):
In Reply to: 12 Volt Coil posted by DFL on January 17, 2007 at 10:27:17:
Two reasons:
If it had been converted to 12 at one time, or if the coil it has is rated for having an external resistor (though it might say 12 volt on it, it is close to a six volt coil, and is usewd with a resistor on 12v, or without on 6v) If it indicates "for use with a external resistor", and does not have one in the circuit, it will work fine on a 6v tractor. JimN
